Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3189 Questions View all
Vertical lines, only on dark parts screen. Old screen working good.
I purchased cheap screen from aliexpress.
It works, but it make vertical lines when on the screen is nothing very bright.
If whole screen is black, it slowly comes to gray/white, but if some bright pixels are in the way, line disappear.
When i switch back to old screen, it works fine so the problem is in the screen.
But why is this happening? Is it caused by bad grounding or something else?
You can see in video what it doing:
Thanks for any response.
Add a comment
Chosen Solution
If you've tested the old display, and everything is fine there. Then it can only be the new display. See if you can get an exchange from the supplier. Or better yet. Get a refund and get a quality display, from iFixit
iPhone 5 LCD Screen and Digitizer
iPhone 5 LCD Screen and Digitizer Image
Score 2
Add a comment
the likelihood is dirty or improper connections, remove the screen and ensure that the connections are clean and none of the pins are bent or broke, reconnect the screen, if this problem is still persistent then you are dealing with a faulty LCD.
I did cleanning and reconnecting, all pins looks OK.
It looks to me the screen cant discharge or something.
id just replace the LCD, the cost of an screen is relatively cheap, and its a simple job to do.
Add a comment
Add your answer
Albert Yakovenko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 55
