Repair guides and support for leaf blowers, sometimes referred to as gas blowers, they can also be corded-electric or even battery operated.
4 Questions View all
Cannot take out of choke position, without stalling.
Blower will start, and will run slowly in the "choke" position....but stalls when put in "run" position....(In choke position, it runs too slowly to be of any use.)
Score 2
Comments:
Many times this is caused by a plugged vent in the gas cap. Try running it and unscrew the fuel cap part way to see if venting the tank will allow it to run without the choke. If so, then clean the cap with hot water and dish soap or replace the cap with a new one.
by
Next I would replace the fuel filter as they are extremely small and when they begin to plug up they will restrict the flow of fuel. Often when you need the choke on or partially on to run the engine (two-stroke) this indicates the filter because the choke is restricting air-flow and pulling in more fuel.
by
Add a comment
1 Answer
Chosen Solution
Remove the air cleaner and the carburetor. Replace the gas and all the fuel lines with new parts.
Get a carb rebuild kit from a local shop or buy online. Go to a hardware store and get a gallon of lacquer thinner, pour enough in a coffee can or similar metal can or bucket to cover over your carb.
Remove all screws and jets from the carb and dunk everything in the lacquer thinner for about 24 hours.
While everything is apart, be sure to check the tightness and security of the bolts on the engine. A lot of times the nuts or bolts that hold the 'jug' on the crank case come loose allowing too much air in the cylinder causing too lean a fuel/air mixture and hence having to run it on choke all the time.
Use new parts to rebuild the carb. Reinstall carb and fuel lines and air cleaner. Tighten all screws and nuts tightly. Add new gas and it should be good to go.
Regards,
Frank.
PS, search Youtube for your specific type of equipment and chances are you will see a video tutorial on just exactly how to fix the exact problem you are having specific to exactly the type of equipment you did not specify in your question.
Score 4
Comments:
A solid answer +
by
Add a comment
Add your answer
greek4756 will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 320
All Time: 6,791
