Repair guides and support for 27" Intel iMacs by Apple.
1589 Questions View all
Core Duo 2 to i7 in Late 2009 iMac?
Hi fellow fixers!
I was recently given a late 2009 27" iMac running the Core Duo 2 3.06 chip. I'm wondering about doing an upgrade to the i7 860 Lynnfield chip that came as the top of the line chip in this model. I have the skills to do this, I've already had to pull it apart to get it running (HDD was stuffed).
If I can get my hands on the chip, will the motherboard from the Duo 2 take the i7?
Thanks in advance for the help people!
Cheers
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Won't work. You'll have to stay in the Core 2 Duo line.
You can go to the iMac "Core 2 Duo" 3.33 27-Inch (Late 2009)3.33 GHz Core 2 Duo
Processor Upgrade: LGA 775 (Socket T)(E8600)
The i7 uses a
Processor Upgrade: LGA 1156 (Socket H)
UPDATE
Drop more RAM and a new SSHD hard drive to kick it up
RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
Details: Supports 1066 MHz PC3-8500 DDR3 SO-DIMMs (204-pin).
Standard RAM: 4 GB Maximum RAM: 16 GB
Hard Drive
OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade
(you may not need this if the brand of drive is the same as the one you are taking out)
https://eshop.macsales.com/item/OWC/DIDI...
https://eshop.macsales.com/item/Seagate/...
Score 4
Comments:
Thanks for the answer. I was hoping to give it a little more oomph for the kids to use but I'll just leave it as it is.
Cheers!
by
Add a comment
Add your answer
Jared Turner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 102
