Light blinking two times, pause, two times, etc.
How can I resolve the two-blink error on this machine without returning it?
Score 1
Comments:
I have the same problem – HELP!!
by
Here is Nespresso's answer. Didn't work for me.
1. Unlock and open the top of the machine and eject the capsule, if necessary
2. Unplug the machine.
3. Close and lock the top of the machine and plug in.
4. Use either a stopwatch or an app that allows you to set a timer for 35 seconds.
5. Tap the button to turn the machine on.
6. As soon as the light comes on, press and hold the button from the side.
7. Hold the button until the light becomes steady. Once steady, immediately lift the finger.
8. Activate your timer you set for the 35 seconds.
9. When the time is up immediately press the button 5 times as quickly as possible.
10. The light should then blink slowly. After 15 seconds, the light should go steady if error is cleared properly.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Ok so turns out a possible issue is that there is an air pocket in the water line. You can try to get a turkey baster and pump the water feed intake ( the nipple on which the water container sits on). Keep the water container off and try and run the machine over and over again while tilting the entire machine forward about 30 degrees. It worked for me. Good luck
Add a comment
Add your answer
Michael Shohoney will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 157
Past 30 Days: 556
All Time: 1,625
