The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
289 Questions View all
What is this display glitch? Has anyone seen anything like this one?
Video about the issue
Usually it happens when i wake it up from sleep mode, even without lifting the lid.
What do you fine folks think, Is it a GPU or a monitor or a software problem ?
I had recently my display replaced by an Apple Authorized Service Provider, because of 2 dead pixelgroups. The problem occured before the repair too. They told me they run their diagnostics and there isn't anything wrong with the motherboard
Apple Diagnostics runs without a problem with code: ADP000.
Model: Macbook Pro Retina 13" Early-2015 8GB of RAM, 128GB Storage Mac OS Sierra 10.12.2
Comments:
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The blur effect happens when changing user accounts (from user A to user B) or when the account is suspended (timed out) so you need to log back in.
I suspect you'll need to check your user account settings as well as your screen & sleep settings as one or more are setup to expire the active user account.
Score 2
Comments:
@raid1337 I have seen this momentarily on some MacBooks when shutting down too, I think it is a bug with how the OS deals with colour when waking or shutting down. Try what Dan says to see if this resolves the issue
by
@reecee - All of our systems do this when the user account is changed and we set the logout timeout for 2 minutes forcing people to re-login to their systems (tight security here).
The blur effect is to hide what you have open but still leave the screen with the active on the desktop so the screen does not need to refresh what you have. You can see it when you alter the user account just pick someone in the list and you'll see the blur, just hit cancel to get back to your screen.
by
@danj To be honest my problem isn't that after sleeping it requires immediately a password. That's what I want it to do. But the random color, spilled ink-like shaped figures that disappear after a few seconds without touching anything are the ones what I trouble about. My problem isn't the blur effect
by
@danj no, I was talking about the effect @raid1337 mentions in the video, not the blurring.
@raid1337 this effect can be seen on MacBooks or iPads with bad LCD cables, which resolves itself when the cable is moved or prodded, but I don't think this is the problem in your case. As I mentioned in my previous comment, I have seen this happen on MacBooks when shutting down (just before the screen goes black), but I am not sure why this happens. I think it is just an issue with the OS not smoothing the colour in certain scenarios, so it is not a hardware issue, unless it appears/disappears when the screen is moved at certain angles.
by
@reecee I don't think its the screen cable's fault too, because this one is like 3 days old. Here's another video when it appears/disappears without moving the lid. It does occur quite often, but doesn't occur every time when I wake up the mac.
by
Show 2 more comments
Add a comment
Add your answer
Vincent Jozsa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 116
