The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3400 Questions View all
How do I get oil from under the screen?
How do I get cooking oil that was spilled all over the top of my iPhone? Everything works just fine the issue is that the lighting of my screen sucks, there's bubbles underneath it, and it's blurring my back
Add a comment
1 Answer
Chosen Solution
Ehh.. You can't really clean it with 90% isopropyl alcohol. I mean you can, and it could clean most of it, but likely it would distort, or damage your display. I would say it's best to replace it, with a new one
iPhone 5s LCD Screen and Digitizer
iPhone 5s Front Panel Replacement
As for your back camera. Sounds like you need to just remove it, and clean out the lens, which you could do while replacing the display
iPhone 5s LCD Screen and Digitizer Image
Score 1
Are you sure there's nothing else I ca do? I'm trying not to replace it because I'm not sure my warranty would cover it, but as for my camera I was thinking it's just the bubble at the top of the screen?
Check and see if your phone is still under warranty. Also figure out how much they might charge you, for warranty, and how much it would cost to have it repaired
Add a comment
Add your answer
Ashlynn Prater will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 43
All Time: 141
