Is my device compatible with the Microsoft Wireless Display adapter?
Hello,
Does anybody know if Microsoft's wireless display adapter (miracast) is compatible with Epson's EB-S31 projector? I am looking for an easy solution to wirelessly project powerpoint from my surface pro 4 without using a separate wirelesss network.
Many thanks
Add a comment
1 Answer
Chosen Solution
Hi,
Does it work when you connect your Surface Pro 4 to your projector using a HDMI cable, (using a Surface mini DisplayPort to HDMI adapter)?
I ask this because if it does then it may work using the Microsoft Wireless Display adapter.
If it doesn't or if it works poorly then perhaps you may have to confirm with Epson whether or not their EB-S31 is HDCP compliant, as it is not stated in the User Guide for the projector.
Here is a quote from the following link that explains it, scroll down to HDCP section on p.2
If a source device is HDCP-coded and is connected to an HDTV display or projector via DVI/HDMI without the proper HDCP decoding mechanism, the picture is relegated to “snow” or, in some cases, a very low 480P resolution. In order to see HDTV with HDCP compliance, both the source and display devices must be equipped with HDMI/DVI connections that can enable HDCP using “software key” decoding
http://www.necdisplay.com/Documents/Whit....
This quote is taken from the Microsoft Wireless Display adapter product page on Amazon.
....Full functionality not available with non HDCP devices......
https://www.amazon.com/Microsoft-Wireles...
Hopefully this is of some help.
Score 5
1 Comment:
Hi,
Thanks for the information. Yes an HDMI to mini display port adapter does work fine.
Perhaps I will try and see. Many thanks
by
Add a comment
Add your answer
Liam Cottrell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,324
