Will 6s camera connection work on a 6 plus?
I have a bad 6s and would like to take the camera assembly out and just plug it in my 6 plus, will they interchange?
Thanks
Thanks
No, the cameras are not interchangeable. They have different megapixels and connectors.
If I have a 6s plus , can a 6s (normal size) camera function on it ?
Did you get a response? I also want to know if I can use the camera of an iphone 6S to repair an iPhone 6S plus
No, they are NOT interchangeable, and I am not guessing….I have actually tried, although I tried the main rear camera from an iPhone 6s to an iPhone 6 (not the plus model), but i´m pretty sure its the same on the standard 6 and the 6 plus.
The iPhone 6 did not even turn on with the 6S main rear camera installed, as soon as I removed the 6S camera the iPhone 6 turned on again.
Also the 6S rear camera connector did not sit properly on the 6, it felt loose and was very easy to remove, even though the rear camera connectors looks the same on the 6 and 6S.
But as a side note I can tell you that I have installed an 6S front camera/speaker assembly on an iPhone 6 and that works fine, although I think you will not get the additional megapixels that the 6S front camera has?
Yes the camera is interchangeable .
No it is not.
@gigabit87898 please expand this and post as an answer.
@mayer - See above specs. I don't know if the they are interchangeable, but there not the same units.
Can 6 & 6s cameras be interchanged?
Could I fix iPhone 6s camera to iPhone 6. If I could fix it in do they work?
Don't give false answers to people, its not helpful getting answers from people who are guessing.
At least you need to write in your answer that you are guessing and that you actually don´t know the answer for sure. The rear camera is not interchangeable between the 6S and the 6.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 6,350
3 Comments
Depending on the model of the iphone 6s and the iphone 6 plus can you please put a model numder in with your question ????
by Walker wallace
thanks i can't get the model numbers now they chose to go a different route
by latraelmayo
iPhone 6s: Dual cameras
- A rear 12 megapixel, 4K "iSight" camera with 1.22 micron pixels, an f/2.2 aperture, and support for simultaneous 4K video and 8 megapixel still photography
- A front 5 megapixel, 720p "FaceTime" camera
iPhone 6 Plus: Dual cameras
- A rear 8 megapixel, 1080p "iSight" camera with 1.5 micron pixels, an f/2.2 aperture, and both Optical image stabilization and "autofocus with Focus Pixels" (phase detection autofocus capability)
- A front 1.2 megapixel, 720p "FaceTime" camera.
by Dan
