will not connect to the internet, and have a good signal
when I try to get on the internet on my ipod touch it will not. I have a good signal and my passwords are correct.
well i don't really have a lot of info based on the question.
The icon isn't greyed out so it is just trying to connect all the time......?
Shut it down and restart it.
Check your access point (router etc). make sure nothing is changed.......
You could try and somehow restore it to an older firmware or update to a newer one.
these options might fix the problem, might not.
Also you can try and reset your network settings in the ipod, (erasing current settings and trying again.)
You could also manually setup your wi fi network (specify the network name etc). If you have accessed more then one AP with the same network name (SSID) ipod might not like that. (ipod can't figure that kind of thing out, at least when I had a 1st gen that happened, and it did not like that at all)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 746
