Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
459 Questions View all
I lost the use of 3 buttons after spilling water on the keyboard.
I only lost the use of 3 keys. They are under each other so somehow they are connected. I am wondering if it's repairable. Right now I have attached another keyboard by USB connection. It's a hassle but it works.
Add a comment
Chosen Solution
keyboards are single units. you would need to replace the board if worse comes to worse.
However opening it up, and using an Isopropyl 99% alcohal and a toothbrush, id suggest scrubbing at both the connectors for the board, and at the indevidual key sections. may clear out the mineral corrosion, and fix it.
Add a comment
Most Helpful Answer
Here's the guide for replacing a keyboard that should work for your model:
MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement
Score 2
Add a comment
Add your answer
Karen Light will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
