Logicboard compatiblity between 2009/2010 models
Hi,
I recently got two old mbp's from friends.
One is a Mid-2010 2.4 GHz Core 2 Duo (P8600) with a broken logicboard.
The other one is a really beat up Mid 2009 2.26 GHz Core 2 Duo (P7550), but with a working logicboard.
I was hoping that I use the working 2009 logic board to repair the 2010 mpb.
Does anybody know if this is possible?
Comments:
Thanks for your comprehensive answer, Dan!
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Lets start off looking to see if the two systems are within the same series using EveryMac:
We can see these two systems are not within the same series so the possibility of swapping parts is reduced. Next lets look at some images to see if the physical layout of the logic board is the same:
While things look the same the trackpad/keyboard cable I believe is wider on the '10 model. As I don't have these two systems in front of me you'll need to check out the connections to see if they are the same. There maybe other differences that would prevent your alterations. So you do risk damaging things if you force things.
Frankly, since you're putting in a less powerful logic board into the newer system here I think it would just be better looking for the correct logic board within the series and then sell the other system to cover some of the cost.
MacBook Pro 13" Unibody Mid 2009 Logic Board Image
Guide
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
Difficulty:
Difficult
MacBook Pro 13" Unibody Mid 2010 Logic Board Image
Guide
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Difficulty:
Moderate
1 - 3 hours
Score 2
Add a comment
Add your answer
heerko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
