Flashing screen, faulty video display cable?
Hello
Recently my MBP (2.5 years old) screen started flashing (from 4 times/min till maybe 10 times when it warms up). In the apple service they replaced all the logic board, because according to them: nvidia gt 8600 was broken. However it doesn't helped and my screen keeps flashing. Apple technician says that the screen works perfectly fine, except that it flashes.. However he suggest me to replace the screen and it costs a lot...
I wander if it can be not the screen problem, but video display cable fault??
P.s. there're no flashes seen on the external monitor, when it's connected to my mbp.
Add a comment
1 Answer
Chosen Solution
You can certainly try the data cable first as its the less expensive item but be prepared to replace the LCD if that does not work.
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Data Cable Replacement
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Image
Guide
Difficulty:
Very difficult
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Data Cable Image
Guide
Difficulty:
Very difficult
Score 2
Comments:
+ agreed, I would also check the inverter, but it sounds like the backlight.
by
Add a comment
Add your answer
Shilas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,602
