New IC Chip - does it need to be programmed?
Hello,
I got an iPhone 5s which always shows me error 4005 in iTunes and isn't able to restore. I found many solutions to this problem which I will try out in the following days but the most common and most complicated solution is that the IC chip either needs to be reflowed / reballed or to be replaced completely.
My first question is: Is it possible to find out whether the IC is still alright so that it just needs to be reballed instead of being replaced completely?
Besides this there are a lot of videos on the internet that show people replacing the IC just as it is, without programming the new chip in advance or anything. But in here I read that the new IC needs to be pre-programmed to run properly with the phone and you can't just replace it without doing that.
So will the iPhones from the people in the videos just not work in the end or how is it possible they don't pre-program the new IC's? And some of the logic boards from the people's phones seemed to be from iPhone 5's too, so its not older phones or anything.
And my last question is, could you program the new IC by yourself or do you need special tools to do that? Please don't just tell me to bring the phone to a repair shop - even if its too hard of an operation to do by myself I would really like to know what exactly is the hard part so I can decide by myself.
I'm greatful for every answer!
15 Comments
Which ic are you planning on reprogramming?
by iMedic
I found this answer, searching for a solution:
"Im not sure if they can be reprogrammed this way on an iPhone 5, but on the 5S you have to force DFU mode (and i mean force! instructions here: https://www.youtube.com/watch?v=ASXZHaJo...) and restore the device from a mac. The ic gets reprogrammed during the nand repartitioning (on a 5s or newer, again, im not sure about the 5) using the information from the CPU and Baseband CPU."
To me that sounds kind of easy.. If I understand it right you just place the new IC on the logic board and before using the iPhone you just need to restore it so the new chip gets kind of adapted to the other chips. Or did I get that wrong?
by Yannic
The U2 IC if that's the right description
by Yannic
That's actually a good question. It's something that I've been playing with, and haven't successfully gotten a nand off, without damaging the board. In theory, you just have to replace the nand, with a new one, and the phone will have all that memory, from the new nand. There were some videos of guys in China, replacing this and two other chips, to do this, but it was said that they, all three, had to come from a donor phone. I'm still wondering if I can just replace the nand, and it would be fine
by iMedic
@refectio can we get your opinion on this?
by iMedic
Show 10 more comments
