This page is intended for the Asus TF300T tablet released May of 2012. The Android operating system allows for users to use the tablet for multiple tasks.
20 Questions View all
No Touch After Digitizer Replacement
Broken Glass, (Glitchy / Unresponsive Touch At this point) Replaced Digitizer, had zero touch function. Tried replacing digitizer board, same issue.
All connections are good but there is no touch function -
Could it just be a faulty part or is there something else going on here?
Any ideas?
Thank you -
Add a comment
Chosen Solution
Refer to this question: ASUS TF300T replaced cracked digitizer but still not unresponsive
Hope it helps!
Score 1
Comments:
Okay Thank you!
by
Add a comment
It very well could be a faulty part. Industry standard is 1 out of every 10 parts ends up being faulty in some way. Also if the device has a ZIF connection for the Digitizer, make sure that the bracket is still on there and is pressed down completely. For a reference, it is the same on iPad'2/3/4. Hope this helps!
Comments:
Okay Thank you!
by
Add a comment
Add your answer
Marcus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 45
