Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3478 Questions View all
Headphone Jack/Microphone and ear speaker not working
Having strange problems with an iPhone 6.
Calls can only be heard through speaker whilst nobody can hear me. Microphone not working even with voice memos. Speaker works fine but if plug in headphone continues to play through speaker. Have replaced charge port and still same issues. Any advice? Know phone recently had a new screen replaced by another tech if that could have caused issues.
Score 2
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would check for Long-Screw Damage, just in case.
There are three microphones on the iPhone 6. There is one for phone calls/front camera videos, one for noise cancellation and one for the rear camera. Check that they aren't obstructed with dust, wax etc.
Small parts are notorious for being hit or miss. Can you confirm that the replacement port is functioning?
Score 2
Comments:
Just put another board in out of interest and all works so guessing board trouble
by
Did you look to see if there is LSD?
by
How would I spot this?
by
The connections cover was not on phone
by
Look inside the standoffs (where the screws go) circled in red in this image. (iPhone 6 Logic Board Replacement)
You will need magnification to do this. Ideally a microscope but a jeweler's loupe will do. The bottom should look black. If it looks all scraped up, then it may have LSD.
by
Show 1 more comment
Add a comment
It's the front camera flex
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
iPhone 6 Front Camera and Sensor Cable Image
Score 1
Comments:
Screen works fine on other phones, all pointing towards board issue
by
Add a comment
i have the same issue, but the screws were placed correctly... have you found an answer yet?
Add a comment
had the same problem with a customer I replaced the charge port/mic flex and fixed all the problems
Add a comment
Add your answer
Niall will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 118
Past 30 Days: 478
All Time: 2,366
