Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
From which MBP's can I get an upper case for my Late 2011 17-inch?
I have two Macbook Pro's 17-inch: one Late 2011 with a British keyboard, and one mid-2010 with a US Keyboard.
I don't like the British Keyboard so I want to swap the entire upper case to get that US keyboard onto my newer machine.
Is it possible to use the upper case of my mid-2010?
Or do I need to find a Late 2011 upper case?
Can I use an EARLY 2011 upper case for my Late 2011 Macbook pro?
Thanks in advance
Score 1
Add a comment
1 Answer
Chosen Solution
The 2009-2011 models will work for you.
See the parts link on the repair guide:
MacBook Pro 17" Unibody (Mid 2010) Upper Case
MacBook Pro 17" Unibody (Early 2011) Upper Case
MacBook Pro 17" Unibody (Early/Mid 2009) Upper Case
MacBook Pro 17" Unibody Upper Case Replacement
Score 2
3 Comments:
Hi there, thank you for your response. I'm also wondering if I can swap the entire display assembly? I would like my mid-2010 anti-glare on my 2011.
If I'm not mistaken, the iSight on the 2011 model is better than the 2010. Do you think I can put the newer iSight inside my 2010 anti-glare assembly?
Or should I just put all my Late 2011 components into the mid-2010? Any suggestion?
Thanks a lot
by
I started you a new question on this and try to get to it later tonight.
by
Thanks a lot for that.
by
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 84
