Install SSD HD in PowerBook G4 1.5?
PowerBook G4 1.5 12" has a Fujitsu MHT2080AH 75GB HD that is failing.
Can an SSD HD be installed in the Powerbook?
If so, what specs do I need to be aware of?
Will a KingSpec T-60 SATA III 3.0 HD work?
Does it need any kind of adapter? or spacer?
Add a comment
1 Answer
Chosen Solution
No. Your machine uses an Ultra ATA/100. Even trying to find a new one of these will be very difficult (I've looked and have not found one yet, only used.)
update - here's a new one: http://www.newegg.com/Product/Product.as...
http://www.everymac.com/systems/apple/po...
Score 3
Comments:
Does it matter if replacement HD is more than the original 80GB?
Will ATA/33, ATA/66, ATA/100, and ATA/133 work with Ultra ATA connection?
If drive is only listed as PATA/IDE, is there a way to tell if it is Ultra or other faster ATA speed?
(ATA/33, ATA/66, ATA/100, and ATA/133)
by
No, but I would stay under 2TB. The last limitation I remember was on G4s and as 120GB.
by
Add a comment
Add your answer
dstx will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 153
