After replacing BT/WiFi card and cable, no Wifi hardware installed
The other week, all of a sudden, I got a message on the menu bar saying "Wifi: No hardware installed." This is on a mid-2010 MBP 15-inch. Tried resetting SMC, did a OS update. No change. The Bluetooth worked fine, just no WiFi. Went to iFixIt, found that they had WiFi cards and cables, ordered one of each and installed them. Still no WiFi (BT still works fine). I am now awaiting an external WiFi adaptor from Other World Computing to see if that can give me back some WiFi. Given the age of this laptop, I don't want to invest in a new motherboard. If this is merely something related to the OS, I am looking at wiping the HD (I have two installed now, a SSD as a boot drive and a SATA HD as a second, larger drive); I am looking at combining the two drives into a single Fusion drive to make better use of the storage and have one logical drive to deal with. Any suggestions on what else may cause the WiFi to stop would be appreciated.
2 Comments
I would double check the three, gold airport antenna cables are seated properly. Also, the airport wireless card has a cable that attaches to the logic board and the assembly itself. I would check that also and make sure it's seated properly.
by Clayton Jacobs
If it is saying no hardware installed, it is not detecting the wifi card (gold antennas are for strength, so this does not stop it detecting the wifi card if not plugged in).
by Reece
