The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
Trouble starting grand am after replacing bad fuel pump
I'm having this issue on my 04 grand am 3.1l v6, just replaced the fuel pump it was sitting about a year, now I have to use starting fluid to get it started and it takes it getting to temp to even idle right. I have to sit there and pump the gas pedal repeatedly for it not to stall and to get it to Rev up to about 2500-3000 rpms bc it tries to die. I didn't change the fuel filter after replacing the pump, what could be the issue
Add a comment
1 Answer
Chosen Solution
kokeman1987 , Change the filter as it could be causing a restriction, look for any pinched/damaged fuel line while you are at it. If still not starting properly, fuel pump should be tested with a fuel pressure gauge to make sure it is functioning properly 41-47 psi. I have seen new fuel pumps defective right out of the box.The fuel pressure regulator can also cause poor starting when they leak, see link #2. Good luck.
http://troubleshootmyvehicle.com/gm/3.1L...
http://diy-auto-repair.wonderhowto.com/h...
Score 1
Add a comment
Add your answer
kokeman1987 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,374
