Calibrating the Battery After Replacement
I recently replaced the battery in my mid-2012 11in MacBook Air. It does not appear to be holding a charge. For instance, the charging cable's green LED will indicate a full charge, but when I remove the cable, the battery percentage immediately drops to 95%-96%. The battery is also draining at about 1% every 2-3 minutes.
I calibrated the battery correctly - or so I think - after I replaced it. I've also let it drain completely multiple times before recharging.
Any suggestions?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
There is no need to calibrate the battery on this model.
When charge shows 96% or so, drain the battery below 90% and start charging again. 1% every 2-3 minutes sounds totally normal.
Score 1
Add a comment
Add your answer
Craig Guiliano will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 868
