Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
4335 Questions View all
The device does not get switched off on pressing on-off button
the display shows a moving circle only with screen dark since last twelve hours. the device also does not get switched off on pressing on-off button
Add a comment
Chosen Solution
Press and hold the Power button and Home button for ~10 seconds to force a restart of your device.
Score 2
Comments:
Thanks a lot. It worked and I am very happy and grateful to you
by
Add a comment
Sounds like you could have a damaged power button. But let's try this first, even though it says it's for an iPhone
iPhone is unplugged from the socket or the computer.
2. Hold down the POWER button plus the VOLUME DOWN button SIMULTANEOUSLY. If it works, the screen should power off almost immediately.
3. Connect your iPhone to the computer. (when I connected to the computer, my iPhone automatically turned on and was ready to be used again).
The subsequent steps below are for those whose iPhones did not turn on with the above steps. The following steps are designed for you to be able to remotely turn off your "Find my iPhone", so you can do a manual restore from iTunes.
4. Go to www.icloud.com.
5. Click Find iPhone
6. Since the phone is powered off already, it won't be able to locate it. Click DEVICES on the upper bar.
7. Click your iPhone.
8. Click "remove from account".
9. Go to your itunes, and do a restore.
I did not have to do steps 4-9 anymore, because as I have mentioned, my iPhone automatically turned on after step 3.
Score 1
Add a comment
Add your answer
Mahinder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 21
