13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Logic board replaced, won't power on.
Liquid damage. Upon disassembly, found logic board burned where hard drive cable connects. Replaced logic board, replaced hard drive cable, reassembled. Connected to power, and it won't turn on. I see the battery indicator, but nothing happens when the power button is pressed.
I found another thread that discussed the possibility of the charger inlet daughter card being faulty, and that you could jumper two solder points to test, but it was a different model macbook (an older one I believe), is that possible with this one? What could the problem be?
I'm new at this, but I was disgustingly meticulous with disassembly and reassembly.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Look for blackened and or burnt areas or components. Get the battery out ASAP
Score 1
4 Comments:
Did it just burn the cable or the board also?
by
Here's a replacement hard drive cable, maybe that will suffice: MacBook Unibody (A1278) Hard Drive Cable
by
Unfortunately the board looks pretty toasted at the point where the cable connects, it will need a new cable as well though.
by
Replaced logic board and the cable, won't power on: Logic board replaced, won't power on..
by
Add a comment
Add your answer
Patrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,882
