2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
104 Questions View all
Diagnostic for progressive failure: screen, track pad, boot failure.
Based on the research I've done here, it seems like a logic board failure, but I thought I'd share what's happening to see if there's anything I'm missing.
Yesterday the computer would boot and the only thing that was wrong was that the screen didn't work. I could hook it up to a monitor and use it as normal.
Today when I hooked it up to a monitor, it would boot up, and I could track the mouse around but could not click on anything.
I tried rebooting and it failed, getting to about 1/3 of the boot progress bar and rebooting.
Any help is greatly appreciated.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Take it to Apple before the end of the year, the reboot issue sounds like it could be a GPU fault.
Could be liquid damage inside, so would recommend checking this first. Screen issue and reboot issue most likely a GPU fault, these are very commonly affected unfortunately :(
Trackpad issue wouldn't be caused by this, so it might just be a combination of trackpad + GPU issue. Otherwise it will be caused by liquid damage completely. Remove the board and check it for green/blue corrosion.
https://www.apple.com/uk/support/macbook...
Score 2
Comments:
Note the "please select a country" under the Apple on that link.
by
Add a comment
Add your answer
keiboman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
