1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
MacBook Air (3209-A): Not charging, no speaker, no USB, + kernel panic
My MacBook Air is having some serious and very annoying issues.
The computer receives power from the charger, but the charger light does not come on, nor does the battery charge.
The internal speakers are not recognized. They do not show up in the preferences and the volume cannot be adjusted.
Also the (left) USB port on the same side as the charger does not work. The USB port on the other side is fully functional.
When booting the device it takes around 10-15 minutes to complete. When finally booted the device is extremely slow and the fans spin at 100%. The Activity Monitor shows met that "kernel_task" takes up to 400% of the CPU usage.
Things I have done to try and solve this are:
- SMC Reset
- PRAM Reset
- Apple Hardware Test (not booting, error -2002D)
- Check all cables on the I/O and logic board
The MacBook was NOT exposed to any form of liquid damage.
I do have experience in fixing laptops in the past so replacing or measuring parts won't be the problem. Will replacing the I/O board solve my problems?
Add a comment
1 Answer
Chosen Solution
Check the trackpad cable and I/O cable for burnt pins.
Fan spin can be caused by the following on this model;
I/O cable (and board)
Trackpad cable (and trackpad)
Keyboard
Battery
Will probably be the cable (rarely can be bad, even though it looks fine) since this is the bridge to the I/O board and deals with the USB, speaker, SMC sensor (fan spin issue) and PP3V42_G3H communicates with the charger board using this, which will then allow the battery to charge.
Check the I/O port on the board and charging board too, in case this is bad. Try an I/O cable first (most likely) then the board after this :)
Score 2
1 Comment:
@reecee Replacing the I/O cable did the trick right away, can't thank you enough!
by
Add a comment
Add your answer
Mitchell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 181
