Manufactured by Dell Inc., this is a 19 in LCD monitor / TFT active matrix with a native Resolution of 1280 x 1024 and an aspect Ratio of 5:4
2 Questions View all
when I power on my monitor the lights goes off after a short while,
when I power on my monitor it lights goes off after three to five seconds, I can still see words behind the dark screen, what could be the problem ??
Add a comment
1 Answer
Chosen Solution
@ndubz that is a common issue with this model. The capacitors on the power board most likely have failed, causing the backlight to turn off. You can replace those or replace the board if you are not sure about soldering. Use this guide to work on it. If you need to double check it, post some good images of your power board with your question. For that use this guide so we can see what you see.
Dell 1908FPb monitor power supply Image
Guide
Dell 1908FPb monitor power supply Replacement
Difficulty:
Moderate
30 minutes - 1 hour
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Easy
2 - 5 minutes
Score 4
Comments:
I thought about replacing capacitors but I was not sure about it though after power on there was some noise coming from within the capacitors. now I know what to do, thanks alot
by
Add a comment
Add your answer
ndubia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 171
