iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
53 Questions View all
which part I should to buy when on/off button doesn't work
My iPad Air (A1475 model) 's On/Off button no response.
which parts I should to buy on/off button doesn't work
sincely
Comments:
What happens when you try to hold the power button while unlocked? Does the slide to turn off dialog pop up?
by
Hi Ben
no. I tried to hold the power button , however It has been lifeless.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
There is no specific guide for doing the Power button but I would use this guide. There will be some slight differences because you have some extra internal antennas so proceed carefully.
This is the flex cable. This is the full flex and bracket assembly. They both do the same thing, you just need to decide if you want the "buttons" already installed or not. Look at the Guide first to see what is the best option for you.
iPad Air and iPad mini Volume and Power Button Cable Image
iPad Air Volume and Power Button Bracket Assembly Image
Score 2
Add a comment
Add your answer
Hayashi Tsuyoshi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
