Why does tv show single line on screen?
Picture tube needs to be replaced
If it is the old TV with an CRT picture tube, then there is problem with vertical deflection, probably a bad vertical IC or a capacitor. Could also be the problem with deflection coils or the bad connection. Almost 100% the picture tube is good.
If you have a LCD TV, then this type of failure is almost non existent, but I would check the main signal IC and the LCD panel itself.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 312
@darrell4868 what make and model is your TV?
by oldturkey03
