Screen won't dim on iPhone 5s
I replaced a screen on an iPhone 5s and the screen won't dim. I just get a blue tint when dimming the screen in settings. any thoughts on the issue?
The issue wound up being a back Digitizer. Received a replacement screen and now the phone dims correctly
Did you try to put back your old screen like @benjamen50 suggested? If the problem is only with the replacement screen, then go to this page to find out how to return your screen under warranty. The folks here are only volunteers and do not work for or represent iFixit.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 294
5 Comments
Sounds like a faulty screen particularly with the backlight behind the screen.
Where did you get the screen from? Because I haven't heard this issue before with replacement screens. If the old screen works just cracked try the old screen again and see if the brightness adjustment works Auto or not.
by Ben
I got the screen from ifixit.com. Not sure how to go about asking for a replacement screen.
by seelejohn
The old screen didn't have the dimming issues
by seelejohn
Just take a new one lcd replace what ever u install try it first before u close permantly
by bjtech
Contact iFixit about the issue with the screen usually thorough a contact us form / email or maybe over the phone they will sort it out for you.
Explain the problem and request that you want to get it replaced under warranty as there is a defect / fault on the screen.
by Ben
