Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3511 Questions View all
Does changing a front camera cable fix touch unresponsiveness?
A customer gave me an iPhone 6 to replace the cracked screen. After replacing i realized that the touch screen becomes unresponsive. It needs a restart to work again. After contacting the customer, he told me that he had touch issues and the front camera and the earpiece speaker stopped working after replacing an old screen. My question is, does changing the front camera cable and sensor fix the touch unresponsiveness? Are they connected in a way?
Comments:
Could this be a case of touch IC disease?
https://ifixit.org/blog/8309/iphone-6-pl...
by
@legowave440 that is what it sounds like honestly. It has been spreading like crazy.
by
Try replacing the front camera flex first. In one rare case here it fixed their touch issue when the front camera flex was damaged.
If that still does not work yeah most likely touch ic gone bad.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi @ramitabaa. The FCAM and Sensor flex should not have an impact on the Touch functionality. However, the opposite can be true if someone tried to reflow the Touch IC's and applied too much heat. If you want to learn more about Touch Disease, look up my profile for a link to my blog entry or search the web.
On the opposite side of the logic board, where the Touch IC's reside, is a series of passive components that connect, via the FPC connector, to the front camera and sensors. When too much heat gets applied to the Touch IC's, the passives can float off their pads by the expanding epoxy holding them in place and have bad or intermittent contact.
Realistically, this phone needs to be looked at by someone who does micro-soldering repairs to be properly diagnosed.
Score 2
Add a comment
Add your answer
Rami Tabaa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 28
