How do I fix error code P1172 in 2005 Verona Suzuki?
@mike_mac , Mike, Suzuki error code P1172 - Lambda controller limit malfunction bank 1 too lean. Info found at link #1 below.
Possible faults are, low fuel level, low fuel pressure, restricted fuel system(plugged filter/pinched/damaged line , MAF(mass air flow)/MAP(manifold absolute pressure) sensor faulty/malfunction, also check for vacuum leaks as link #2 Suzuki trouble shooting forum recommends.
Make sure fuel level is good(not empty), check for clogged gas filter(replace if it has not been done recently) and pinched/damaged fuel line, have fuel pressure checked(replace fuel pump if found to be too low) and or clean/replace MAF sensor. Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 183
