Won't turn on after moving it.
Hi there we have the above model and t.v, if it is moved for any reason it switches itself off . The first time it happened, it came back on after about 3 weeks, this time it was moved very slightly and turned off and hasn't come back yet. Any advise anyone could give would be great. Thanks:)
Comments:
Hi, When you connect and switch on the power outlet do you get any power light indication on the TV? If not does it come on when you move the TV, or if it does come on does it go out if you move the TV?
If this is happening it seems as if there may be a loose connection in the power area of your TV.
With the power cord unplugged from the wall outlet, check to see if the power inlet socket in the TV feels 'firm' by gently trying to move the plugged in power cord plug from side to side and see if there is movement.
by
Hi there no lights, or power at all, last year when it did this it came back on after 3 weeks??
by
Add a comment
1 Answer
Chosen Solution
Hi @fluff111 ,
Here is a link to an earlier Ifixit question regarding your model TV which had the exact same problem of no power indication.
No power to TV.
It shows the power supply board for your model TV. This is a good place to start looking for your problem, if you know what you are doing with a DMM (digital multimeter) and a bit of knowledge regarding how to test electronic circuits.
If you don't I suggest that you contact a reputable, professional TV repair service and ask for a quote.
Score 2
Add a comment
Add your answer
Tracey will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 82
All Time: 615
