Won't turn on after moving it.
Hi there we have the above model and t.v, if it is moved for any reason it switches itself off . The first time it happened, it came back on after about 3 weeks, this time it was moved very slightly and turned off and hasn't come back yet. Any advise anyone could give would be great. Thanks:)
2 Comments
Hi, When you connect and switch on the power outlet do you get any power light indication on the TV? If not does it come on when you move the TV, or if it does come on does it go out if you move the TV?
If this is happening it seems as if there may be a loose connection in the power area of your TV.
With the power cord unplugged from the wall outlet, check to see if the power inlet socket in the TV feels 'firm' by gently trying to move the plugged in power cord plug from side to side and see if there is movement.
by jayeff
Hi there no lights, or power at all, last year when it did this it came back on after 3 weeks??
by Tracey
