I got a 4411
I got a 4411 whats that mean?
Maurice Aburame 0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsink screws are tightened securely to the board/heatsink holes. This error appears when the CPU overheats. The heat can't be dissipated to the heatsink and/or the heatsink isnt cooled properly. This can be caused by improper thermal compound usage or if the error comes up instantly while booting the console, the heatsink will likely not be making any contact at all with the chip. In rare cases it can also be a faulty temp sensor. From here and here for more info. Here isthe RROD kit that may help you with that.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 928
3 Comments
Maurice Aburame double check your error code. Something does not work with a 4411 code.
by oldturkey03
@oldturkey03 0 = 4 so the error is 0011
by Gigabit87898
@gigabit87898 understood but learned a long time ago, never assume always clarify:-)
by oldturkey03
