Can't clear message NO DRIVE install usb flash drive i,ve never used a
i need to clear a message box that says no drive that keeps me from logging on when I press OK nothining happens
Hi,
Try 'booting' into the Windows Recovery Environment and go to the Troubleshooting option to 'repair' your Windows installation. Do not select reset as this will erase all your data and reinstall Windows.
Here is a link that gives you options on how to access the Windows Recovery Environment area.
https://www.lifewire.com/how-to-access-a...
Hi,
Try booting up and then when you get the error message, force power shutdown by holding the power button until it shuts down. Do this 3 times in a row. By the 3rd attempt it should go into the Windows Recovery Environment window. Then go on from there.
If this doesn't work do you know anyone who has a Windows 8.1 computer? If so you can make a bootable recovery USB (8GB size is preferred) drive from their PC. It is located in Control Panel > Recovery. Be patient it takes about 40-60 minutes to create. It will have all the system files necessary to recover your tablet.
Hopefully it will detect that you have a USB drive installed when you insert it and boot from it.
this won't work because this message doesn't clear to allow me to log on any more suggestions
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
2 Comments
these suggestions won't work because I can't clear this message to log on when i press OK the message doesn't clear any more suggestion thank you for trying
by william hightower
I used method one using my on screen keyboard and the problem was cleared up and tablet is operational again
