A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
No beep, no power.
I was playing my ps4 suddenly only the console turns off not my tv so it cannot be a power outage. I unplugged the console from the back even tried to plug it on another plug and nothing.
Add a comment
1 Answer
Chosen Solution
There are several things to check. First of all, make sure that the power plug is securely plugged into the back of the console. It's common for it to come loose and cause this type of problem. Secondly, I'm not sure if you live in an area with cockroaches or not but if they have gotten into your PS4 they may have caused the power supply to go bad. Third, it's possible that the power supply just went out. While this isn't super common it does happen.
I hope this helps.
Score 1
1 Comment:
I have the same problem but I've already done the first procedure but nothing happened. Second I'm sure that cockroaches is not the problem. How about if the third procedure is the problem what should i do? Fyi, already tried also to to push the power button but only 1 beep heard and it turns of and still the unit does not open.pls advice what should I do. ynx
by
Add a comment
Add your answer
Gerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
