Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Old screen displays colored lines, new screen is black
My original iPhone 6 screen does not work. It only displays a few vertical lines, sometimes white and sometimes multi colored. When plugged into the computer the phone is recognized by iTunes but can't be accessed because of passcode. I tried a new screen (with no home button or camera) but that screen displays nothing. No lines or anything. The edges of the underside light up when I hit the sleep button so I'm assuming the screen is working. Any ideas what's going with it and how to get my computer to recognize the phone. When I put the old screen back on the lines show back up. Thanks
2 Comments
I only have the one replacement screen. When I put the original (broken that only displays the few vertical lines) the lines show up again. But the new screen is blank. Would it have anything to do with the new screen not having the home button or camera switched over? I don't want to take apart my wife's working iPhone 6 to test the new screen, she would kill me if I broke her phone too. I took it to a mall repair kiosk and they tried a new screen but nothing showed up on theirs either. I'll send it in to a better repair shop I guess.
by
The Home Button & Camera have nothing to do with it.
by
Add a comment
1 Answer
Chosen Solution
You need to isolate a variable here. You may have a bad replacement screen or you may have a problem on your phone or both.
If you put back the original screen, does it still exhibit the line pattern or does it too not show anything? If you can repeat the pattern on the original screen then that may prove that the new screen is faulty. Do you have access to another iPhone 6? That way you could test the replacement screen on a known-working device. Also, double-check your connections and always disconnect the battery before working on the screen.
Finally, there are lots of low-quality screens out there. Did you buy from a reputable vendor or on eBay/AMZN? If you have an easy warranty path, I would try to return the screen and get a new one.
Otherwise, a repair shop will be able to properly diagnose your problem as they have all the parts on hand.
Score 1
Add a comment
Add your answer
Fran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
