Formally called the Chevrolet C/K.
186 Questions View all
fuel gauge quit working.Its stuck at 1/4 tank.
fuel gauge stuck at 1/4.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
melfart6in, There are a few reasons that may cause fuel gage stuck, check the fuse for being blown as a first step. Bad/corroded/loose connections on fuel gage wire/plug(clean and tighten) especially and ground you see, faulty in tank sending unit rheostat(test and replace if defective). Fuel gage defective(test and replace). Use the trouble shooting links below for more info on diagnosing, testing and repair of fuel gage. Good luck.
https://www.chevytrucks.org/tech/gasgaug...
http://www.americanautowire.com/view-faq...
https://www.youtube.com/watch?v=tOHDmBnK...
Score 2
Comments:
After changing fuel pump gauge was a little off.The problem was me,I wasn't putting enough gas in it. I'm embarrassed.
by
Add a comment
Add your answer
melfart6in will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 147
All Time: 770
