Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
After screen replacement phone won't turn on
Hello
I've replaced the whole display from my Iphone 6. I didn't disconnect the battery, so I put the flex cables in turned my phone on and it worked perfectly, then i wanted to put the metal shield on and afterwards my phone wouldn't turn on anymore. It doesn't find it on iTunes, I tried again and again the cables are in the right positions, the screws where never mixed up or something I also tried the restore mode and dfu mode nothing. When I put my phone on charge it gets warm so I think it's still alive?
Thank you very much for every help!
Add a comment
1 Answer
Chosen Solution
Based on what you say, it does appear to be related to screwing the bracket back on.
Ideally you should always disconnect the battery but I don't think this is your problem. Even if you didn't mix up the screws, if you over-tighten them you can still cause damage to the logic board.
Try to remove the bracket again and see if the phone works. Inspect the connectors with a magnifying glass or jeweler's loupe.
Get back to us with your observations.
Score 2
1 Comment:
Thank you I will try it!
by
Add a comment
Add your answer
fnha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
