DIY guides for many household repairs, ranging from furniture to plumbing solutions.
3865 Questions View all
fireplace light's up but doesn't give off Heat
Have a movable fireplace in a mantle housing and the fireplace light's up but doesn't give off Heat it has 3 switches any suggestions on how to fix it
2 Comments
Check if under manufacturer’s Warranty as you do not want to void it if it has to be dissembled to trouble shoot. Always be careful and unplug the device.
As may be with yours, some electric fireplaces have a separate switch that disables the heating element, see if switch is turned on and try. Check electrical wiring and look for any loose connections.
Switch/Safety(limit)/Heating element may have burned out or faulty which you could have tested. Check wire running to your thermostat for properly attached if equipped. Links that may be helpful and aid in diagnosing and repair of your fireplace, manual pdf, google search for your model if needed. Good luck. I hope this helped you out, if so let me know by pressing the helpful button. http://www.crossroadsowners.com/forums/f...
https://www.youtube.com/watch?v=orJB96ML...
http://www.electricfireplacesdirect.com/
https://www.google.ca/url?sa=t&rct=j&q=&...
by
@toby1 what make and model is your fireplace?
by
Add a comment
1 Answer
Chosen Solution
@toby1 ,Toby, Check if under manufacturer’s Warranty as you do not want to void it if it has to be dissembled to trouble shoot. Always be careful and unplug the device.
Score 2
Add a comment
Add your answer
TobySenteno will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 208
