2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
Only chime, no graphics
Hi guys, I've got a MacBook Pro Retina late-2013 with the exact same issue. Only chime, no graphics. It doesn't respond to any commands (except for Reset SMC...that, according to the light on the charger, it did work). But other than that, I think I tried everything.
It loops on that chime even without the SSD inserted. The cause of this was actually software (bad OS installation, don't ask, it was a stupid mistake) and when I realised it, I force shut down the machine, which made it worse. Ever since I did that, all reboots are going into boot loop like this. No graphics on the screen (the screen does light up normally though). Only startup sound.
Update: this has been fixed in a repair shop by replacing the EFI chipset on the motherboard.
7 Comments
Check to see if it not an Early 2013 with has a repair program for the video
by
The MacBook is not under warranty. And the model is late-2013. :(
by
Is the SD back in it?
by
Tried cmd+r?
by
Yes, the SSD is back in it. And it doesn't respond to any boot commands, except for power, of course. I tried Option (select boot drive), Command + R, PRAM reset, SMC reset, Safe Mode, Target mode, Diagnostic mode (the D key upon boot)... I don't know what else to try.
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
This sounds like it could be a logic board issue. If you press the option key while booting, does it load into the startup disk picker?
Score 2
5 Comments:
No, it doesn't. Any idea what exactly on the logic board could cause this?
by
It could be one of so many issues, I wouldn't be able to pinpoint the issue, unless you have some electronics experience and are comfortable with a soldering iron and multimeter. Otherwise, I would recommend taking it to a 3rd party store that specializes in MacBook logic board repair.
by
Ok. Fixed it in a repair shop by replacing the EFI chipset on the motherboard. Thank you very much for your feedback.
by
Very strange fix. I take it that you were not the original owner.
by
I wasn't. But I'm pretty sure it was a firmware issue caused by that force shut-down. I think the system was attempting an update on that firmware when I interrupted it. I'm just super happy that it works now. :)
by
Add a comment
Add your answer
arsradu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,023
