2.26 or 2.4 GHz / White plastic unibody enclosure
620 Questions View all
Charger Wont Charge Battery? % Dont go down
MacBook White 2010
Hi!
I have a 60W Magsafe Charger with a strange problem!
The charger will not charge the battery, only shows green light, but never amber.
The percentage of the battery doesnt go down either and does charge with my brothers charger, but not with my charger?
I have tried to do a SMC Reset, clean the charger and the charging port on the MacBook, but still dont work?
Just annoying that it keeps the battery at the same percent, but wont charge it.
It doesnt work on my brothers MacBook either.
Charger dead, or what?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If it charges with your brothers charger but will not charge your machine or his and his charges both:
you ,have a bad charger. Take a look at the pins and see if they are extending (sometimes a pin will get stuck down) use a toothpick to push them in and out to test. That failing, replace it or use your brothers till a replacement comes in.
Apple MagSafe 1 AC Adapter
See the pin out on the right side of the page to test:
https://en.wikipedia.org/wiki/MagSafe
Apple MagSafe 1 AC Adapter Image
Score 3
Comments:
Yes, My brothers charger does charge my battery, my charger does not charge his battery.
Will try the thing with the pins
by
Didnt work to push the pins, so i guess the charger is bad. Thanks for the help
by
Add a comment
Add your answer
viffviff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 70
