The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
265 Questions View all
Why washer goes to "ol"during wash/rinse spin
elite,model 110.28032701, after wash no water in tub,clothes still wet,and code"ol"on display
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
See my previous answer on this:
The washer has ol on it at the end
Score 1
Comments:
this answer is for a maytag washer,my question was for a kenmore
by
It's the same answer. OL is an overload code.
by
Add a comment
Most Helpful Answer
@eddie9115 just checked your washers manual and "oL" still stands for overload. With your washer this could be caused by a bad bearing in the outer tub, a bad control board as well as a bad motor sensor. Check to see if you can ran the diagnostics mode and see what it tells you. Let us know. Kenmore-Dia.pdf
Score 2
Add a comment
Add your answer
edward grabowski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 55
