Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
218 Questions View all
iPod is frozen on hold.
My iPod Photo is stuck on hold. I cannot reboot. I also tried installing a hold switch from another iPod Photo & that didn't work, so it isn't a bad switch. Any ideas? New hard drive? New logic board? Something else?
Score 1
Comments:
@zookie does it show the lock symbol at all? does it change as you move the slider?
by
Add a comment
Chosen Solution
I got the problem solved with the help of a contributor to ifixit & am posting the solution here in case it helps anyone else. In my case the ribbon wire going from the switch to the logic board had somehow become a bit loose & wasn't securely fastened. The ribbon feeds into a small square in the upper right corner of the logic board. I simply pushed down on the square & heard a click. Problem solved. Ifixit has some great photos of the iPod insides that show the components I am referring to.
Score 2
Add a comment
If this is a 4th generation honestly I'd probably lean towards replacing the device with another 4th or even 5th gen model. Not typically a cost effective repair.
Comments:
Thanks Matt. I actually got an iPod Touch recently, but the 4th gen photo is my favorite model. It actually does some things the Touch doesn't & almost everything is easier to do on than on the Touch. The click wheel is genius.
by
Add a comment
Add your answer
Les Girouard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 96
