The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
375 Questions View all
Why Isn't my tablet turning on?
Okay, so this morning I dropped my tablet, while getting out of my car and it fell on the ground and cracked slightly. I could still use it, however. The touch ability worked and everything worked as normal, just that it had a crack at the corner and across it. So then later this evening it suddenly turned off?? Like it wont even respond when I put it for charge or touch the home screen button??
Also, I don't know if this is going to be helpful, but a few minutes before the tablet turned off I had put it on top of the laundry basket. The clothes weren't really that wet, but I don't know if somehow the screen is extremely sensitive to water and it seeped through the cracks and damaged the tablet further or something??
Please respond!!
Score 1
Add a comment
1 Answer
i think i would like you to charge your tablet for 30 min and make sure you see the charge is coming to tablet .
than press the power key and hold for like 40-50 sec and wait see if this turn on . t think charger socket may be broken . try opening the tablet using ifixit tools and see if you check the charger socket .
Add a comment
Add your answer
dangerousdream29 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 67
