Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
170 Questions View all
Mid 2014 MacBook Pro battery in early 2015?
Hi, I need to troubleshoot an early 2015 MacBook Pro 13" battery. Can I safely plug a mid 2014 battery in an early 2015 logic board? Is it even the same connector? Thanks a lot!!
Add a comment
1 Answer
Chosen Solution
They have very different P/N's:
MacBook Pro 13" Retina (2015) link to IFIXIT Battery
  • Specs: A1582 - 11.42v 74.9Wh - 6559mAh
  • Apple P/N's: 661-02361, 020-00009
MacBook Pro 13" Retina (2014) link to IFIXIT Battery
  • Specs: A1493 / A1502 - 11.34v 71.8Wh - 6330mAh
  • Apple P/N's: 661-8154, 020-8146, 020-8147, 6712-6700
MacBook Pro 13" Retina (Late 2013/Mid 2014) Battery Image
MacBook Pro 13" Retina (Early 2015) Battery Image
Score 4
Thanks for your answer! What does P/N's stand for? Positive/Negative?
P/N = Part Number
Alrighty! :) I know they have different parts since the 2015 one is slightly bigger, that's why I'm asking this question. Is the connector different ? If so would it damage the 2014 battery somehow if I plug it in?
Different battery not interchangeable.
OK now it's clear! Thanks!
Add a comment
Add your answer
Remi M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 206
