Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
no (any life) (touch) respond after replaced cracked screen
hello people, i have an iphone 5, i have tried everyting i can find on the internet, but still have no any respond not usb, no charging, still nothings. also when iphone worked in the past have no any touch respond. 2 ic's i think are damaged.
Add a comment
1 Answer
Chosen Solution
You have two separate issues here...
  1. You have a charging issue
  2. You say you had Touch issue before
Regarding your charging problem, have you tried a new, known-good battery? Have you looked at your charge port to see if there is any debris? If you can rule that out, then you probably have a charge circuit failure on your Tristar IC (U2).
Regarding your Touch issue, the iPhone 5 is not known for suffering from Touch Disease so this may be more related to a bad screen or improper connection.
You don't give us enough information to help you, please give us more details.
Score 1
1 Comment:
new, know good battery, still no life, but 1 of the 2 touch ic's i don't have a good feel about it looks like there is tiny small plastic exploded off from the top of black block. And especially the small black block close left under the battery connector doesn't seems ok. I have still new display installed, so it's logic that this can't be the problem.
by
Add a comment
Add your answer
Michel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
