iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Questions View all
iPad doesnt turn on. New Battery doesnt change anything!
Hi :)
So i got an iPad Air that wont turn on. It doesnt react to anything.
Now i changed the Battery, but the iPad is still dead.
Home-/Powerbutton doesnt change anything.
So is the Logicboard broken or do you see any chance?
Thanks!
Add a comment
1 Answer
Chosen Solution
What is the history of the iPad before you got it? Was it water damaged or did it suffer strong impacts. Those are things that could cause logic board damage.
There could be a problem with the charging circuit (U2) but it is tough to say since you don't know if the battery you put in there is in good condition. Check the battery with a multimeter to insure it has the proper voltage (it should be around 3.7V). If you have access to the schematics, you need to check if the battery voltage is getting to the logic board.
Beyond that, depending on your experience troubleshooting logic boards, you may need to find a qualified repair shop that does micro-soldering repairs for a proper diagnostic.
Score 1
Add a comment
Add your answer
ripper2k6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 121
