Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Will replacing the housing fix my antenna problem?
Hello guys. I have a iphone 6 which the cellular antenna stopped working. It just says searching, and after a while it comes up "no service". I have done all steps with the software, without luck.
I replaced the dock connector, and after that the cellular antenna worked, and i got signal. But after a while it stopped working again.
My frame is also really bent, i and i was watching ebay, where you could buy new frames with almost all the parts premounted. So i am asking for advice, if i replace the frame, with all the new parts, what are my odds of getting signal again? I don't have any other iphone 6 here, otherwise i could test the mainboard to see if that is broken or not. What do the more experienced guys here think?
Thank you!
Add a comment
Chosen Solution
Hi,
With it being bent this could cause issues, especially with the logic board flexing.
You could try replace the housing yes, but if this doesn't solve your issue, then it could be a logic board issue.
Also try simple things like a new SIM card. :-)
Score 3
3 Comments:
Thank you, i will consider that. But not sure yet, maybe just sell it with a big loss as well. Because i am not sure if it is worth investing in a frame.
http://imgur.com/a/nRdwD
Here is a picture of the bend.
by
Worth a try, as it may work.
And if it doesn't you'll probably be able to sell it a bit more looking new.
by
Thank you sir, i will most likely try this
by
Add a comment
I replacement the housing with parts preinstalled . Now the service works like a charm. SO HAPPY!
Thanks guys!
1 Comment:
No problem! :-)
by
Add a comment
Add your answer
Iver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 118
