Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1232 Questions View all
iPhone 5c won't charge past 3%
My iPhone 5c won't charge and the charger is brand new but after I plugged it into my moms Dodge Journey USB port my phone stoped charging , now it dies and turns back on but doesn't charge past 3% and the lighting bolt doesn't pop up , does it need a new battery ? Help
Add a comment
1 Answer
Chosen Solution
The iPhone charging subsystem can be damaged by non-MFi (Made for iDevice) certified chargers. Based on the sequence of events you describe, this is what happened to your phone. Cheap dollar-store charging bricks also can cause this.
While it is possible that your battery is defective, I believe that the Tristar(U2) IC on your device was damaged by the USB port. This is not a DIY repair unless you have experience in micro-soldering.
If you have access to a known-good battery, you can always replace it. If a known-good battery does not charge, then it is a U2 problem.
iPhone 5c Battery Replacement
The 5C also suffers from micro-fractures on the logic board so this could also be the root problem on your device. A qualified repair shop that does micro-soldering should be able to troubleshoot your device properly if you don't want to do it yourself.
Score 1
Add a comment
Add your answer
Shadiamond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,879
