Why my vacuum cleaner does not suck? unmounting instructions please
vacuum cleaner elettro gt 893701
I need unmounting instructions because my vacuum cleaner has stopped to work
Cause 1
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 2
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 3
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
i was not clear, my vacuum cleaner does not turn on more
Well that explains why it won't suck! Do you get anything, can you tell if it is getting any power, what's the history, was the failure gradual or all at once? Have you examined the cord and the plug, is it burned?
i can't tell if is getting any power. it stopped to work all at once , the plug doesn't seem burned
Of course you tried it in another room in a different outlet with a different circuit.
yes i've tried it in another room and with a different outlet
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 569
